Lift All tank oil level ?? Super M with tank under gas tank.
Posted by Mike1972chev on September 20, 2011 at 18:00:37 from (99.31.14.38):
Hey guys,
My hydraulic reservoir drips around where the shaft comes out of it on the right side of it.I recently took it apart to clean the tank out and I installed a new o ring,Still dripping slightly.Shaft is just SLIGHTLY sloppy in the bore.(I wonder if I should have took the time and had that hole oversized and installed a bushing????)
But what I was wondering where IS the oil level is supposed to be anyway??? Is it supposed to be BELOW that shaft ?Have I been overfilling it all this time? It looks to be kinda hard to put a dipstick on this one because of the 45 deg elbow right at the tank?(I know they make a stick for the "belly"pumps.)
My hydraulic system either has to run TWO 3x8 cylinders on my 3 point hitch or ONE 3x8 cylinder on my plow or disk.NEVER all at the same time.
I do not wanna EVER run my live pump low!!!(I know they cost from $600.00 to $800.00 bucks !!!
