Re: Lift All tank oil level ?? Super M with tank under ga...
Posted by bc on September 21, 2011 at 22:40:06 from (71.158.223.75):
In Reply to: Lift All tank oil level ?? Super M with tank under gas tank. posted by Mike1972chev on September 20, 2011 at 18:00:37:
If you fill it from the top, just make your own dip stick with any piece of wood or dowel or just use a tape measure. Do this the next time you fill it with the side plug out. Then you never have to pull the side plug again. I made a stick I run to the bottom and marked the level. I also mark the dipstick when I overfill it by 5 gal. When you change it the next time, just check the level as you add each gallon to make a guage on your dip stick.
