Re: Update on Farmall C stuck clutch
Posted by Janicholson on September 20, 2011 at 18:24:43 from (67.72.98.45):
In Reply to: Re: Update on Farmall C stuck clutch posted by CT8N on September 20, 2011 at 16:06:46:
The other warnings are to be taken seriously. If the tip of the drawbar where the chain is attached is outside of the radius of the tire, the tractor cannot go over backwards if things go slowly. If the wheels go upward rapidly, the inertia can and will topple the tractor.
If I were to invent a best practices way of breaking a clutch loose, I would make a bracket that replaced the starter and held the Flywheel teeth from turning.I would put it in high gear, and pull the tractor rearward with a come along to a protected tree, or heavy vehicle. I would pull on it such that the tires were sliding a little, then with a brass drift through the starter hole next to my bracket, I would rap the flywheel a sound smack to viabrate it.
Jim
