Super M live pump
Posted by jtbartlett on September 21, 2011 at 15:57:26 from (71.169.139.85):
I have never removed the live pump from a super M before. Due to an unforseen problem I need to remove and disassemble the live power pump. Can I remove the bolts and pull the whole pump and distributor assembly together? I know the live power pump is driven by the cam gear but is it indexed, or timed like the cam gear is timed to the crank gear? I have only seen behind the timing cover on a different M and cannot remember if the pump gear needs to go back EXACTLY the same way it comes out. Thank you.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
