Re: Super M live pump
Posted by David G on September 21, 2011 at 16:07:01 from (72.101.90.181):
In Reply to: Super M live pump posted by jtbartlett on September 21, 2011 at 15:57:26:
I added the pump assembly to my H. I would recommend to set the engine on TDC, and mark the postion of the rotor on the distributor, and the distributor on the pump. That will guarantee you get it back where it was.
You might also want to mark the slot position between the distributor and the pump if you take that apart. The setscrew was loose on my pump, I would check that and locktite it while it is apart.
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
