Posted by GWMiller on September 23, 2011 at 20:23:53 from (216.82.171.238):
What is this linkage on the left side of the hydraulic valves on my 460 gas?
I bumped it a couple months ago and discovered that the unused steel lines that ran under my seat were rusted out. I replaced those steel line with hoses and ran the hoses long so i can plug them right into the cylinder for the fast hitch when I put it on.
When I put it all back together everything seemed to run well except that there is a slight whine in the hydraulics if this linkage is in the wrong position. The whine also goes away if I actuate the other hydraulic circuits that run my loader.
What does this linkage do? what position does it need to be in when I put the fast hitch on?
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
