Re: Identifying linkage on 460
Posted by pete 23 on September 24, 2011 at 09:27:34 from (74.32.234.149):
In Reply to: Identifying linkage on 460 posted by GWMiller on September 23, 2011 at 20:23:53:
When you say , when I put the fast hitch on do you mean it does not have the fast hitch on it now or do you mean when you move the lever to operate fast hitch. All 460's came with teledepth if they had the fast hitch. Many had hitchs put on later with out teledepth. Many have thrown away the teledepth valve and went with the regular aux valve to operate hitch. Your linkage is not hooked up therefore is in limbo. When all hooked up correctly the linkage self centers the valve thus the name teledepth. In reality it is a follow up linkage. Valve linkage follows hitch movement. If you need to keep using tractor like it is , lock that link so it cannot move and then find true neutral where hydraulic system is on low pressure by moveing lever and then leave it alone.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
