Worked H good today.
Posted by David G on September 24, 2011 at 17:41:22 from (205.215.206.18):
I took the H into town and filled it up today, then pulled the disk
for a couple of hours helping a friend grade around a new
driveway.
It ran very well and pulled the 10' disk in 3rd gear just fine. The
disk has some bad coulters and will need maintenance this
winter.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
