Re: Worked H good today.
Posted by sflem849 on September 25, 2011 at 12:30:09 from (69.197.84.39):
In Reply to: Worked H good today. posted by David G on September 24, 2011 at 17:41:22:
I'm with David, it was mean (and I am known to not be so nice sometimes) He probably worked his tractor twice as hard as most of the tractors on this forum. Hell, it had something hooked to the drawbar!!! That is better than 90% of the guys on here.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
