Re: M/Super M Gear Shift Levers with single or double bends
Posted by D Slater on September 25, 2011 at 16:55:29 from (184.15.20.91):
In Reply to: M/Super M Gear Shift Levers with single or double bends posted by scotc on September 25, 2011 at 05:30:01:
Fellows if you have a SM gas with a starter mounted by 2 bolts its a stage one. If 3 bolt starter mount its a stage 2. Hydraulics were a attachment, so a stage 2 could be bought with a belley pump. There was several changes to the chassis from stage one to two, starter, clutch housing, battery box location are some. So unless the SM tractor has parts added or switched in its lifetime, a 2 bolt starter is a stage 1 and a 3 bolt is stage 2. No ifs or ands about it. This is non diesel SM tractors I refer to.
lblock the hydraulic pump on the tractor is a M&W brand.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
