Re: M/Super M Gear Shift Levers with single or double bends
Posted by lblock on September 25, 2011 at 17:08:46 from (98.222.20.238):
In Reply to: M/Super M Gear Shift Levers with single or double bends posted by D Slater on September 25, 2011 at 16:55:29:
Thanks You Are Da Man ! Mine is two bolt also proves his point.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
