Exactly!! Just because it CAN be done does not mean it SHOULD be done. Lots of things will not be correct, and besides all of that, the swinging drawbar is to be used ONLY when pulling tillage equipment such as a disk harrow. All other equipment is to be hooked directly the horseshoe, except for PTO powered machines, and then you need the triangle shaped hitch plate bolted to the horseshoe. The triangle plate provides for the correct distance so the pto shaft will not bind up when making turns.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
