Belly pump on H
Posted by Nich on August 21, 2000 at 19:28:45 from (38.14.117.230):
I have a belly pump that leaks under preasure. The fluid comes out of the shaft driving the pump. should i take it down? what is the easiest way to take it down? thanks in advance.
Post A Followup
: Re: Belly pump on H
