Re: gas and motor oil in base
Posted by ih_bug on August 21, 2000 at 20:03:55 from (216.129.37.50):
In Reply to: gas and motor oil in base posted by dave on August 21, 2000 at 17:30:56:
change the oil!!
to much gas thins the oil and will cause escessive wear on bearings
check to see if there is a thermostat installed and make sure when using it that engine temp comes up to normal
also does the engine smoke? to rich a jetting on the carb? to much gas will wash the cylinder walls and cause wear and also thin out the oil.
Post A Followup
: Re: Re: gas and motor oil in base
