Re: What is the FULL purpose of a swinging drawbar anyway???
Posted by Keith Williams on September 27, 2011 at 11:19:58 from (208.81.151.130):
In Reply to: What is the FULL purpose of a swinging drawbar anyway??? posted by Mike1972chev on September 27, 2011 at 11:00:15:
Mike,
When I plowed with the H back in the 70's, I had a hillside hitch to adjust the drawbar position. I am in East Ohio and we have some hills. My farm had 53 ft Contour strips. So you go out one strip and back two strips up. I was constantly adjusting the position of the drawbar so that the first bottom would take the same "bite". With the old ford plows you ended up having to make an extra round or two on the strip you where throwing the furrows down hill.
Later I plowed with a 3 pt plow that had an adjustment in the hitch to make it plow straight.
Keith
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
