What is the FULL purpose of a swinging drawbar anyway???
Posted by Mike1972chev on September 27, 2011 at 11:00:15 from (75.149.81.173):
Hey guys,ME again.
I am in the process of making a "fine adjuster" for the swinging drawbar my Super M to help "tweak in" the draft on my #16 plow for plow day and was wondering: What is the FULL purpose of this thing? Is there a situation you would just EVER let it swing freely and NOT have it pinned solid?
I have not really used it for anything other than my 2" trailer ball and car trailer so far(pinned solid in the center position) and I was betting some of you "senior"/"more wiser" gentlemen on this forum could tell"novice" me ALL of the different uses,scenarios that the swinging effect helps in different implements and different situations? :)
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
