The Drawbar is loose to swing when appropriate, and pinned when needed. The important factor is that the point of pull (Belly Pin point) will actually favor the turn by pulling toward the side of the drawbar displacement because it is in front of the rear wheels. Pulling a 4 section spike tooth drag with an Farmall H, using a ring and link chain style hitch to a 2" pipe main tube was a 20 hrs/yr task. The only time I ran the drag up on a tire was when my cousin pinned the drawbar, and the point of pull was forced to be centered behind the tractor. With it pinned the turning radius was 135'. With it free, the radius was about 45' (I could make a circle about 20 ' in diameter with the inside edge of the drag. (wheels were set mid axle dish out) JimN
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
