Re: What is the FULL purpose of a swinging drawbar anyway???
Posted by Mike1972chev on September 27, 2011 at 17:35:42 from (108.67.95.193):
In Reply to: Re: What is the FULL purpose of a swinging drawbar anyway??? posted by jackinok on September 27, 2011 at 12:47:53:
I dont think anyone is saying THAT "jackinok".
What IS being said is you can adjust BOTH the swinging drawbar AND the plow hitch to adjust the draft!I am STILL learning this,but you could leave the drawbar centered and adjust the plow hitch to get it,or you could use both to get it?
If the draft was off it COULD pull right or left?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
