let me see.you actually believe swinging the drawbar on a tractor makes the plow turn right or left?you could hitch a properly setup plow twenty feet to the side of a tractor and it wouldnt pull right or left.maybe by doing this you are compensating for tire slippage on a really steep side hill?regardless of where your plow is hitched to the right or left if properly setup it will pull straight down the centerline of tractor.unless some one has figured out a way of moving center of draft on a plow i dont see how it could do otherwise.now if your tractor was slipping sideways on a steep hill i might believe off hitching to the side would change draft on tractor.i would have to think about that one,
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
