Re: H brake seal replacement
Posted by Jason the Red on September 27, 2011 at 18:41:49 from (99.109.191.179):
In Reply to: Re: H brake seal replacement posted by Tom Fleming on September 27, 2011 at 17:10:07:
Tom, you wouldn't happen to have the NAPA part number for those seals do you. I'm planning the same project this winter. Thanks.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
