Re: What is the FULL purpose of a swinging drawbar anyway???
Posted by Lmack on September 27, 2011 at 20:48:31 from (72.145.203.180):
In Reply to: What is the FULL purpose of a swinging drawbar anyway??? posted by Mike1972chev on September 27, 2011 at 11:00:15:
Most of our implements were mounted and then we had a 200 with a fixed drawbar. On tractors with a swinging drawbar we would pin the drawbar when pulling side feed implements like a bailer or corn picker to center it up better. If we were bailing and the wheels were out to cultivator width for 38" rows the right wheel would be into the windrow. Pining the drawbar all the way to the right would make it work.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
