Re: What is the FULL purpose of a swinging drawbar anyway???
Posted by RPM1941 on September 28, 2011 at 06:46:10 from (173.24.196.59):
In Reply to: What is the FULL purpose of a swinging drawbar anyway??? posted by Mike1972chev on September 27, 2011 at 11:00:15:
One of the reasons was to standardize the PTO demensions so that it would not cause problems with PTO driven implements when turning or crossing waterways. In respect to the telescoping of the sliding shafts.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
