Re: What is the FULL purpose of a swinging drawbar anyway???
Posted by Super-H-Mike on September 28, 2011 at 07:29:37 from (76.164.145.65):
In Reply to: What is the FULL purpose of a swinging drawbar anyway??? posted by Mike1972chev on September 27, 2011 at 11:00:15:
We only used it unpinned when pulling the 4 section drag, otherwise its handy for hooking up wagons and such.
For picking corn and plowing I use this, as I like it to be more solid.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
