Re: What is the FULL purpose of a swinging drawbar anyway???
Posted by Mike1972chev on September 28, 2011 at 08:24:35 from (75.149.81.173):
In Reply to: Re: What is the FULL purpose of a swinging drawbar anyway??? posted by mkirsch on September 28, 2011 at 06:23:44:
Sorry mkirsh,Maybe I used the wrong terminology there?But any movement of the drawbar or the plow hitch WOULD effect the draft,wouldnt it ????
I am doing what you said.I am adjusting the rears on my Super M to be fully narrow with wheels "dished out".
The hitch is adjustable on the #16.It should be REAL close.All I am doing is making an adjuster to"fine tune "the swinging drawbar! (Moving like ONLY an inch or 2 at the VERY most to get that first bottom as close as I can get it.)The swinging drawbar will never get too far from the center of the U bar!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
