Re: What is the FULL purpose of a swinging drawbar anyway???
Posted by mkirsch on September 28, 2011 at 06:23:44 from (64.80.110.74):
In Reply to: What is the FULL purpose of a swinging drawbar anyway??? posted by Mike1972chev on September 27, 2011 at 11:00:15:
Swinging the drawbar for plowing is not about draft. It's about getting the first bottom to take a full cut with the tractor's wheel in the furrow.
It's a "cheat," and not really the correct way to do it. For normal plowing, you would adjust the tread width on the tractor, and set the plow straight behind the centerline of the tractor.
It's an acceptable temporary solution when you've got a big tractor and a small plow, or you're just plowing a small garden, or you're on a side hill.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
