Re: charging system farmall m
Posted by Bob M on September 28, 2011 at 12:33:00 from (69.207.87.100):
In Reply to: Re: charging system farmall m posted by NORMAN MOYER on September 28, 2011 at 11:57:06:
Norman - If you have a 4 terminal regulator installed, the field resistor on the LHDB switch is no longer being used. The resistor's function is now accomplished automatically by the regulator.
The other resistor on the LHDB switch (the heavier one) was the dimmer resistor for the headlights. Unless you still wish to have a "dim" setting for the headlights it is not needed either. A simple on/off switch to control the headlights will work fine!
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
