Re: charging system farmall m
Posted by NORMAN MOYER on September 28, 2011 at 11:57:06 from (69.133.114.43):
In Reply to: Re: charging system farmall m posted by pete 23 on September 28, 2011 at 11:45:21:
do not have original cut out . am using 4 terminal regulator ,L ,BAT. F on one side and GEN on other side . did away with rotary switch and need something to do the same task that the rotary switch did controling the field in a cut out system
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
