Re: What do the experts think?
Posted by Janicholson on September 28, 2011 at 20:33:16 from (96.24.99.126):
In Reply to: What do the experts think? posted by d282 on September 28, 2011 at 20:17:01:
To assess the coil the engine must turn (be cranking) and the coil wire must be held 1/4" from a ground. Assuming you did that, The cranking demand on the battery may be taking more than normal voltage drop, this starves the coil for enough voltage to run. Another issue is plugged up fuel filter. Assuming it has a Rochester carb of some type, there is a small tube in the intake at the choke that is cut off at an angle. The carb bowl can be filled by putting gasoline in this tube. (about 1/2 cup max) do that then give it a start. If it starts, the fuel pump or filter may be to blame. Jim
