Re: What do the experts think?
Posted by Too Far Gone on September 29, 2011 at 07:17:06 from (67.221.197.94):
In Reply to: What do the experts think? posted by d282 on September 28, 2011 at 20:17:01:
After you turn it over a little,hop up there and look straight down the carb throat and open the carb manually with the linkage,You SHOULD see it spray some gas in there if its right.Otherwise a tune up will probably do it.Ive even seen plugs that were old that would have spark on the outside and not even fire under compression
