Re: farmall m cuts out when under a load- push clutch in ...
Posted by Mike1972chev on September 29, 2011 at 09:26:06 from (75.149.81.173):
In Reply to: farmall m cuts out when under a load- push clutch in and ... posted by wallylucius on September 28, 2011 at 23:11:13:
Yea,if its not the cap vent,it might be the coil or ballast resistor???
My Super M was doing this a few weeks ago.When my ballast resistor was getting hot,it was "cutting out"the ignition.(I ohm ed it right when it quit.)I have seen MANY coils "break down" when they get warm,as well.You let them cool off and they will start working again,then drop back out when warmed up again.
