It seems kinda strange?Reading your statement,you really could not have fire at the plugs and NOT at the coil.
If you dont have fire at the coil,but DID have at the plugs at one time where you checked it.Then something has JUST quit on you!
Start with the points.If dirty,I have seen them work fo a few and then quit because of corrosion issues.While you have the distributor cap off,chech terminals in there for corosion as well.They are bad about it !Then check coil and voltage going to it.
If you have fuel soaked plugs and gas in the exaust like you are saying,then I really dont think you have a fuel problem at tis time.Most likely ignition.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
