Three things to do. Remove the bottom of the carb and remove the float and needle from the upper half. rub some fuel through the seat. Put it back together. This washes dirt out of the seat. Clean the points with 240 grit paper, then wipe them with a folded dollar bill. (no lint) Remove the plugsand squirt 2 squirts of engine oil into each cylinder for prelube, and assist with compression. Jim
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
