Thanks! I'll try what you suggest. I have other gas powered equipment that I have let sit for a long time without running and I don't have any problem starting them. I have let a lawnmower set for over 5 years, put gas in the tank, and it fired right up. So, why do I have such a problem with this tractor?
Today's Featured Article - Product Review: Lead Substitutes - by Mike Schordine. Lead was oriinally added to gasoline as an upper cylinder lubricant. It lubes the valves and seats. If you rebuild the motor, you could use hardened seats and valves, and unleaded fuel. But if your old tractor runs good, a simple lead substitute added to the gas is a perfectly reasonable solution. And, if you are like me, your tractor is under cover, but it sits outside. So with every temperature change, the humidity in the air collects in the fuel tank, in the form of water.
... [Read Article]
Latest Ad:
[More Ads]
