How do you know - or what do you mean - that it's not firing on those two cylinders?
Did you test for spark at each of the cylinders?
If not - grab an extra spark plug, and just pull each wire one at a time and use the spare plug to see if it's sparking.
If they're not, then you can focus 100% on the distributor.
If it is sparking all around, it doesn't prove things are 100% in the distributor, but good enough that you should move your focus to valves. Adjust the valve lash, and in doing so you should be able to see if any are stuck or not working properly.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
