super c suddenly missing on 3 and 4
Posted by tempola on September 29, 2011 at 20:37:54 from (72.161.231.251):
I was doing to light work with dads old 1953 super c this evening, and all of a sudden, it stated missing so badly it would not pull it's self.
I pulled off the hood, checked the ignition, points wires, firing order, even put in new plugs. No go. cylinders 3 and 4 is simply not firing,
I'm suspecting a faulty cap, or blown head gasket, cracked head, or even a broken cam (unlikely)
Any thoughts fellas? I'll run a compression check tomorrow
Andy
