Posted by GordoSD on October 02, 2011 at 06:53:58 from (216.106.252.125):
In Reply to: Brake job on SM posted by lblock on October 02, 2011 at 02:05:48:
Due to 60 years of wear the inner surface of the "drum" and the surface on the tractor where the disc hits havw worn quite a bit. You can't get enough expansion even with new discs to fill up this wear. You have to planeoff about .090 off the drums. Any shop that planes heads can do it for you.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
