Re: Super A Clutch release resolved
Posted by Hendrik on October 03, 2011 at 06:46:35 from (194.53.253.51):
In Reply to: Super A Clutch release resolved posted by Goodman on October 03, 2011 at 05:55:48:
Thanks for reporting back to the forum! One man's fault is another man's lesson.
Grooves in a bushing help to retain and to distribute grease in a bearing. If the grooves are in a special "spiral" pattern, they help to build up pressure in the bearing (similar to a centrifugal pump), without the need for an external pump (as used in engines, for instance).
See link below.
HTH, Hendrik
