Posted by Janicholson on October 03, 2011 at 20:07:52 from (67.72.98.45):
In Reply to: wobblin' wheel posted by ADLM on October 03, 2011 at 18:18:35:
The Bull gears must be removed from the axles in the rear final drive case. Blocking them up with dowels of bolts keeps them from falling and being hard to realign. Taking the top cover off might be easiest, Working through the PTO hole might be too tight on a C. Once that is off, the wheels and tires are off, the axle housing and axle can be removed to get at the bearings. All parts are heavy, use great stable wooden blocking to support your work. use a cherry picker to lift components. The axle may be worn and need to be replaced. The bearings are available by part number from Motion Industries or other bearing store, Napa may also have them. Some seals may need to be purchased from the dealer, But cross reference the numbers first to Chicago Rawhide, or National. Jim
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
