Posted by ADLM on October 03, 2011 at 18:18:35 from (98.67.143.180):
The rear left wheel on my Farmall A has a wobble in it. I can rock it back and forth when it sits still and i can tell its definitely the axle that has some "slop" in it. So i looked at a parts manual. Apparently there are two bearings in there, along with seals. Also, i think I have a leak above the axle where the differential exits the transmission case. Additionally, the brakes are shot, so i might as well replace the brake on this side while I've got everything apart, right? So, where do I buy replacements for these bearings, seals, and brakes? How expensive is this going to be? How hard is this going to be?
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
