Re: wobblin' wheel
Posted by JRSutton on October 04, 2011 at 09:42:50 from (75.130.109.233):
In Reply to: wobblin' wheel posted by ADLM on October 03, 2011 at 18:18:35:
Just to add my 2 cents to what's already been said...
If you're going to replace one brake, you probaly should replace both.
Things can get a little dangerous if one side slips and the other catches solidly! Especially zipping downhill in 4th gear.
Not that these things actually "zip" in 4th....
Point is, you're going to have it blocked up anyways, and have all the right tools out...
Might want to also consider buying 2 of any parts/seals you need for the same reason.
