I am familiar with the newer Gresen valves,but I am not sure about the ones you have?
If they are an OPEN center valve with the "out" port on the valve being an actual Power Beyond port,they should work fine.Like Jim was saying,you can "air check" them to make sure they are OPEN thru the center.(But that deosnt proove them to be "power beyond" capable,that just means he center is OPEN. If they were a CLOSED center valve,you wouldnt get any oil passing thru the valves(going on to the next valve in series)unless the first valve was actuall being "worked" and the "exiting" oil out of that first valve would THEN be going to the second valve in series.Does that make sense?It can be a little confusing to explain sometimes.
The one question I didnt ask was where is the LAST valve in the series "out" port hose going too????? Is it plugged off?Is it maybe "dead heading" somewhere???Is it feeding another function somewhere else???
Today's Featured Article - Fabrication (Who Me? Make it myself?) - by Chris Pratt. First of all, what are the reasons for not fabricatin your own parts? Most judgements on what should be purchased rather than fabricated stem from: Originality - If the tractor restoration is to be 100% original, it is likely that you should spend the time and money to locate the component in the used or New-old-stock market. Since this can be extremely difficult, you may want to fabricate the item or purchase a modern replacement temporarily, but eventually, you s
... [Read Article]
Latest Ad:
[More Ads]
