Re: Super M hydraulics problems
Posted by jtbartlett on October 05, 2011 at 05:45:16 from (71.169.139.21):
In Reply to: Re: Super M hydraulics problems posted by Mike1972chev on October 03, 2011 at 05:17:40:
Thanks Mike, the valves are 2 Gresen 575 and 2-way and 1 Gresen 300 1 way, just checked them again. What is the proper way to set these valves up? The valves are connected to each other from "out" port to "in" port so I was under the idea that an open center would push oil directly through the valve bodies until a function is selected.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
