Re: cub still not starting
Posted by JRSutton on October 06, 2011 at 11:21:13 from (75.130.109.233):
In Reply to: cub still not starting posted by jeep258goat on October 06, 2011 at 10:45:55:
First thing to check, is to be SURE you're at TDC of the COMPRESSION stroke.
It's easy to forget there's an exhaust stroke, and a compression stroke.
Pull the plug on the #1 cylinder (closest to fan) and put your finger on the whole to feel for the compression.
One the exhuast stroke, the exhaust valve is open, and there's very little pressure build up in the cylinder as the piston comes up.
On the compression stroke, the pressure increase dramatically and can easily be felt.
THEN watch for TDC at the top of that stroke.
