Re: Re: Re: H Governor problem
Posted by Dan on August 23, 2000 at 09:55:52 from (199.176.179.4):
In Reply to: Re: Re: H Governor problem posted by The Red on August 23, 2000 at 09:30:19:
Thanks, as my spring is really loose at idle. Any idea why i can't get 1850 RPS's? One thing that I didn't mention earlyer, what is the adjustment bolt with a locknut on it that is located to the bottom back side of the governor? There is a spring on the inside end of this adjustment bolt. It seems to have someting to do with the idle, as it only contacts the rockershaft during idle.
Thanks for your help, as you can tell I'm new at Farmalls, I've done a lot of work with Fords.
Dan
Post A Followup
: Re: Re: Re: Re: H Governor problem
