Re: Farmall H govenor
Posted by Janicholson on October 06, 2011 at 20:46:41 from (67.72.98.45):
In Reply to: Farmall H govenor posted by truckerlary on October 06, 2011 at 20:19:41:
There is a high probability that the connection between the carburetor throttle plate and the governor shaft (in the 2 screw connection at the top front of the carb) is out of place. There is a tang and slot arrangement that is difficult to assure is in place as it is assembled. Checking this is easy, getting it right is a "hold your mouth right" operation. The symptoms are idle, or Way over speed scary not good. If this is the case, start there. Jim
