Posted by smallercrawler on October 07, 2011 at 07:24:24 from (166.82.254.181):
Hi all, I ran into a problem with an Continental F124 gas engine in a 1950 U.S. Trac dozer. As these engines were used in some IH/Farmall, thought someone might help. Engine has been running fine for last several years, started and worked for a couple hours each month. Started up good yesterday and ran ok for an hour or so. Began stalling/missing, thought it was what is called gasoline these days so checked fuel system-nothing apparent. Was running at 1500 RPM when it backfired 3 or 4 times, coughed, and stopped. Would crank, but not start with frequent "chuffing"/backfire. Found distributor rotor had broken on shaft. Cleaned plastic from distributor, installed new one and same thing. Changed to new plugs (gapped ok), 2 known good coils, and checked point gap, compression good, still same problem. It now looks like rotor is between 2 plugs and trying to fire both, rotor moves smoothly-doesn't appear cam gear damaged. Distributor body hasn't moved. What has apparently changed timing by about 45 degrees?? Sorry for long post, trying to anticipate questions. Thanks for any help offered.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
