Try replacing the condensor with a new unit. The rotor might have damaged the wire on it or it may just be bad. The rotor appearing to be attempting to fire two plugs at the same time will seem that way because it actually starts firing before it reaches the contact in the cap(advanced timing)if it were to fire exaclty when it was closest to the contact the engine would be firing at Top dead center and have very low power. It is possible though that the roll pin that holds the gear in position on the bottom of the distributor shaft may have broken and not keeping the gear from slipping on the shaft. Good luck
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
