Posted by Doug Kieta on October 07, 2011 at 10:34:18 from (71.54.105.139):
The center bearing (part #8097-D) on my 51H is worn and the shaft vibrates all the time. The shaft does not appear to be worn although I have not dismantled it yet. Does this bearing have a bushing in it? If so, what size is it? If not, does anyone know where I can get a bearing that is not worn?
Also, there is play between the steering worm and the sector gear. I can't see how to get it out to tighten up the steering other than by replacing either one or both of the gears. Any tricks you guys have used to solve this problem?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
