Posted by Janicholson on October 07, 2011 at 16:30:07 from (67.72.98.45):
In Reply to: H Steering Problem posted by Doug Kieta on October 07, 2011 at 10:34:18:
The center steering wheel shaft (8097D)bearing can be replaced if it is not available at the dealer, it can be rebushed inexpensively. The top bushing in the front bolster shaft (43805DR), the Worm bushing (41096DBR), and Worm seal (359042R91) can all be replaced to reduce the worm gear to Sector backlash. Beyond those, new sector or worm, or both are needed. Mobil 1 synthetic chassis grease is good for the box, and does not leak out, Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
