M Farmall brake pedal shaft
Posted by Haas on August 23, 2000 at 13:32:58 from (129.37.117.187):
It looks like transmission fluid is coming out around the shaft on my MD to which the brake and clutch petals are attached. I assume this shaft must go through the transmission and that there is a seal where it goes through the housing. How to change the seals??? I assume remove the pedals and slide the shaft out. Then pry out the old seals and press in new ones. Then reassemble. Is all this correct?? Or...is there something more complicated here??
Post A Followup
: Re: M Farmall brake pedal shaft
